DAQ:PCI-6229:Is it possible to output pulses generated by the counter to P0 to P31 using Visual C?
My customer wants to know if it is possible to output pulses generated by the counter to P0 to P31(Port 0 of M-series board) using Visual C. I got samples for generating pulses as well as writing to DO. Would you please tell me how to merge the 2 programs? By the way, I do not know much about Visual C.
Thank you for your help,
Jun
(2,731 Views)
It seems a little strange. Why doesn't your customer just write out a pulse train they define to the digital ports (not using the counter). Or, just use the output pin for the counter. What is the reason for creating the output on the counter and then outputting it again through the digital ports?
StuartG
(2,728 Views)
