DAQ USB 6009 self test failed in LabVIEW2012
Hi All,
I have recently installed LabVIEW 2012 and DAQmx 9.6 (and tried with higher version also) in my PC with Windows 7. I have  measurement and automation explorer 5.4 version. I am trying to work with USB 6009 DAQ device. Everything looks compatible but when I try for self test of the DAQ, it fails. However, I used to use this device (since I purchased it last year) with other PC which has WindowsXP operating system and old version of LabVIEW 8.5.
All I can see with LabVIEW 2012 is a message "An error -88302 occured." and "This might be internal error."
If anyone has some idea to fix the problem, please let me know.
devkotaj
(3,422 Views)
Hello devkotaj,
I found this knowledge base article that seems to address your question. Apparently, the behavior you described is caused by a corrupt DAQmx driver, a repair should fix it.
Hope this helps.
Tarek B
(3,381 Views)
