DAQ assistant not opening in vi
I am using a NI 6008 DAQ to make a measurement as part of a test. I placed the DAQ Assistant in the VI using express vi, DAQ assistant. When I run the VI, the DAQ assistant doesn't seem to run, or  initialize the daq to the settings I have stored. If I manually open the DAQ assistant sub vi and run it, then close it, the vi works fine every time after that. This seems to be a problem whenever the PC is rebooted, or if the usb port is disconnected then reconnected. Not sure why the DAQ Assistant isn't running inside the VI.
Bob
(2,920 Views)
Problem solved, I didn't have the data input wired on the DAQ assistant that sets up the digital output port.
Bob
(2,905 Views)
