DAQ board for ADXL202AE accelerometer
I am tring to find a good DAQ board that will be connected to ADXL202AE (Analog Device). It's first time to use this accelerometer. The PDF file is attached. X out and Y out will be used. I also would like to know where X out and Y out can be connected in any DAQ board.
(2,641 Views)
Greetings,
In addition to a DAQ board you will most likely need some sort of signal conditioning for your accelerometer. We offer two primary conditioning lines, either SCXI or SCC. For accelerometers you will be interested in either the SCXI-1530 or the SCC-ACC01.
SCXI-1530
http://sine.ni.com/apps/we/nioc.vp?cid=4310〈=US
NI SCC-ACC01
http://sine.ni.com/apps/we/nioc.vp?lang=US&pc=mn&cid=3387
Both of these signal conditioning systems are compatible with our line of Multifunction Input/Output (MIO) DAQ boards. Your selection just depends on your requirements for sampling rate, resolution, channel count, and form-factor.
I recommend using the following utility to narrow down your search for a DAQ card.
Data Acquisition (DAQ) Hardware
h
ttp://sine.ni.com/apps/we/nioc.vp?cid=1037〈=US
From glancing over the specs for this accelerometer it loks as if Xfilt and Yfilt are just analog output channels. In this case, you can just connect these to the analog input lines of your MIO DAQ board. Once you select the DAQ board that is the best fit for you, the User Manual can be found online at http://www.ni.com/manuals.
Justin Britten
(2,641 Views)
