DAQ damage
You do not need to upgrade LabVIEW or buy a new DAQ board. All you need to do is upgrade to the newest verison of the DAQ driver, or repair your installation of the the DAQ driver. You can find the driver here:
http://www.ni.com/support/daq/versions.htm
Hope this helps,
Anuj D.
Message 11 of 15
(1,116 Views)
Hope this helps,
Anuj D.
Message 12 of 15
(1,117 Views)
You do not need to upgrade LV or buy a new board. You simply need to re-install the driver. The driver will come with the necessary VIs.
As mentioned earlier, you can download the driver here:
Anuj D.
Message 13 of 15
(1,115 Views)
After downloading the DRIVER where do I store the file. After installing will it allow the current programs in LV6.0 to RUN normally? Or do I have to change all programs to LV7.1. In my country NI is actively promoting LV Express. Is LV Express 7.0 or 7.1?
Message 14 of 15
(1,109 Views)
After downloading the driver, all you need to do is run the installation program. You can download it to a temporary location on your file, and the installation program will take care of putting the files in necessary locations on your PC.
Additionally, LabVIEW Express is both LabVIEW 7.0 and 7.1. LabVIEW Express was initially used with LabVIEW 7.0 because it was the first version of LabVIEW to use Express VIs. LabVIEW 7.1 is an exentension of this.
Anuj D.
Message 15 of 15
(1,074 Views)
