DAQ: error 10041
I use a DAQ card to measure a voltage, and my program works. But when I create an application of my program (xxxxx.exe), there is an error: "error 10041, The specified task ID is invalid. For instance, you may have connected a taskID from an Analog Input VI to a Digital I/O VI."
Do you know what i'm supposed to do?
(3,077 Views)
in your LV  program, you may be setting some channels / devices without making them defaults. It will probably work.  But when you create the application, the original value (the default) is used.
(3,072 Views)
To make current values default in your front panel controls, open your VI and then go to the Menu "Operate >> Make Current Values Default". Save your VI and rebuild your executable with the application builder. It should work now. Do not forget to install NI-DAQ on all the target PCs where your executable will be installed.
Hope this helps.
Matthieu G.
(3,047 Views)
