DAQ error -200284, error -200292 or warning 200010 occurred
Dear all,
In principle I have an easy task to do: Applying a voltage ramp (e.g. 0-6V in approx. 200ms) and synchronously read in an analog signal. The whole procedure should be triggered by an external TTL signal at a rate of one Hz.
Hardware:
NI cDAQ-9174
Mod1 NI 9215 (BNC)
Mod2 NI 9264 (DSUB)
Mod3 NI 9402
Mod4 NI 9403
Software: python 2.7
But, from time to time it returns one of the following errormessage:
RuntimeError: nidaq call failed with error -200284
RuntimeError: nidaq call failed with error -200292
RuntimeError: nidaq generated warning 200010
I tried to reduce code, but I wanted to keep the main functionalities:
import ctypes
import thread
import time
import numpy
from PyDAQmx import *
nidaq = ctypes.windll.nicaiu # load the DLL
class AnalogInOutputThreadPlot():
   def __init__( self, AO_Vstart,AO_length, AO_time):
# define waveform, # of samples, ...
       self.sampleRate = 500
       self.AO_Vstart=AO_Vstart
       self.AO_time = AO_time
       self.AO_length=AO_length
       self.periodLength = int(AO_time*self.sampleRate)
       self.waveform=AO_Vstart + AO_length * numpy.linspace(0,1,int(self.periodLength))
   def run(self,n,tsleep):
       self.taskHandleOut = TaskHandle(0)
       self.taskHandleIn = TaskHandle(0)
       self.taskHandleOut2 = TaskHandle(0)
# prepare the wave form in a DAQmx compatilbe list
       self.dataIn = numpy.zeros((self.periodLength,),dtype=numpy.float64)
# create AI task including clock
       self.CHK(nidaq.DAQmxCreateTask("",ctypes.byref(self.taskHandleIn)))
       self.CHK(nidaq.DAQmxCreateAIVoltageChan(self.taskHandleIn,
                               "cDAQ1Mod1/ai0","", DAQmx_Val_Diff , float64(-10.0),float64(10.0),  DAQmx_Val_Volts,None))
       self.CHK(nidaq.DAQmxCfgSampClkTiming( self.taskHandleIn,  "", float64(self.sampleRate), DAQmx_Val_Rising,
                               DAQmx_Val_FiniteSamps, uInt64(self.periodLength)))
# create AO task including clock
       self.CHK(nidaq.DAQmxCreateTask("",ctypes.byref(self.taskHandleOut)))
       self.CHK(nidaq.DAQmxCreateAOVoltageChan( self.taskHandleOut, "cDAQ1Mod2/ao0", "", float64(-10.0),
                              float64(10.0), DAQmx_Val_Volts, None))
       self.CHK(nidaq.DAQmxCfgSampClkTiming( self.taskHandleOut, "", float64(self.sampleRate),
                                DAQmx_Val_Rising, DAQmx_Val_FiniteSamps, uInt64(self.periodLength)))
# reserve all eserves the hardware resources for AI
       self.CHK(nidaq.DAQmxTaskControl(self.taskHandleIn,DAQmx_Val_Task_Reserve))
# implementing internel trigger for AO (slave) via AI (master)
       self.CHK(nidaq.DAQmxCfgDigEdgeStartTrig(self.taskHandleOut, "/cDAQ1/ai/StartTrigger", DAQmx_Val_Rising))
# implementing external trigger for AI
       self.CHK(nidaq.DAQmxCfgDigEdgeStartTrig(self.taskHandleIn, "/cDAQ1Mod3/PFI0", DAQmx_Val_Rising))
# set output buffer
       self.CHK(nidaq.DAQmxCfgOutputBuffer (self.taskHandleOut,500))
# start loop of AI and AO ...
       for i in range(n):
           # start AO and AI in individual threads (slave first)
             thread.start_new_thread(nidaq.DAQmxStartTask,(self.taskHandleOut,))
             thread.start_new_thread(nidaq.DAQmxStartTask,(self.taskHandleIn,))
           # actual writing AO ramp
             self.CHK(nidaq.DAQmxWriteAnalogF64( self.taskHandleOut, int32(self.periodLength), 0,float64(2),
                             DAQmx_Val_GroupByChannel,self.waveform.ctypes.data,None,None))
           # actual reading AI
             self.read = int32()
             self.CHK(nidaq.DAQmxReadAnalogF64( self.taskHandleIn, int32(self.periodLength),float64(2),
                             DAQmx_Val_GroupByChannel, self.dataIn.ctypes.data,ctypes.byref(self.read),None,None))
           # delay to give tasks enough time to finish
             time.sleep(tsleep)
           # display AI data
             ydata=self.dataIn
             print ydata[0:10]
           # stopping tasks so they can be used again in next run
             self.CHK(nidaq.DAQmxStopTask( self.taskHandleOut ))
             self.CHK(nidaq.DAQmxStopTask( self.taskHandleIn ))
       # clear tasks in the end
       self.CHK(nidaq.DAQmxClearTask( self.taskHandleOut ))
       self.CHK(nidaq.DAQmxClearTask( self.taskHandleIn ))
   def CHK( self, err 😞
       """a simple error checking routine"""
AIO=AnalogInOutputThreadPlot(0, 6, 0.2)
AIO.run(10,3)
Does anybody have any idea what I need to change to get rid of the error messages?
Kind regards
(5,203 Views)
Do you have more information on where the errors occur?
Did you follow the instructions in the error descriptions?
e.g. error -200292:
"Some or all of the samples to write could not be written to the buffer yet. More space will free up as samples currently in the buffer are generated.
To wait for more space to become available, use a longer write timeout. To make the space available sooner, increase the sample rate."
error -200284:
"Some or all of the samples requested have not yet been acquired.
To wait for the samples to become available use a longer read timeout or read later in your program. To make the samples available sooner, increase the sample rate. If your task uses a start trigger,  make sure that your start trigger is configured correctly. It is also possible that you configured the task for external timing, and no clock was supplied. If this is the case, supply an external clock."
warning 200010:
"Finite acquisition or generation has been stopped before the requested number of samples were acquired or generated."
Best,
Anna
Anna Vogl
Certified LabVIEW Developer
(5,158 Views)
Thank you for your response!
I tried to take the suggestions of the error messages into account, but only with minor success.
I was playing around with sample rates and buffer of both AO and AI, following the following guidlines (which I found in the NI support and the error messages):
AO:
Buffer should be at least 2x the samples to write
In order to avoid glitching, low sample rate and large buffer
AI:
High sample rate makes samples available sooner
In addition, I chose the timeout >> samples to read(write) / sample rate.
After some trials, and getting rid of the manual buffer assignment (DAQmxCfgOutputBuffer), I ended up with a setting (AO: sample rate 500/s, buffer 200, samples to write 100, timeout 2s; AI: sample rate 5000/s, buffer 1000, samples to write 100, timeout 2s) which allowed me to runt the simplified program stable for 1k runs.
But, if first of all, this setting causes a mismatch between the AO and AI. So if I want to monitor the response to my AO using the AI, I cannot choose all these parameters at will.
Furthermore, when I add additional data analysis, e.g. plotting the data or fitting the AI signal, I get again a variety of error messages depending on what I changed (200015, 200547, 200288, 200284 …).
The errors 200015,200547, 200288 occur when the DAQmxWriteAnalogF64 function is called.
The errors 200284 occurs when the DAQmxReadAnalogF64 function is called.
The warning 200010 occurs when the AI task is stopped.
I am still puzzled why this is not working …
Kind regards
(5,115 Views)
