DAQ express is broken (cDAQ-9172 9481 )
I am a reasonably experienced labview user and am running Labview 8.5.1. on several machines.
On the particular machine I wish to use this hardware on I have connected a cDAQ-9172 using USB with a NI 9481 relay switch.
The hardware shows up when connected and using automatiion explorer I can turn on and off the individual relays without a problem.
Now in Labview itself I drag DAQ express to my block diagram, double click and the hardware configurator appears.
I can go to generate digital output and again control the relays manually beautifully.
Now here comes the problem: when I press OK, the window returns to the block diagram but ... the DAQ express does not update.
It has no terminals I do see the "updating bar" complete to 100% but the DAQ does not work.
In my other 2 labview installations on two other machines I do not have this problem, but I cannot switch computers.
I would really appreciate any help you might have.
I already "repaired" the labview installation with the cds but it did not help.
THanks,
-Peter
Message Edited by PeterdB on 04-08-2010 11:06 AM
(3,186 Views)
just to update, it is the DAQ assitant VI that I was referring to. I erroneously mentioned it as DAQ express VI.
(3,183 Views)
Hello Peter,
Sometime we have seen similar issues with express VIs when certain behind-the-scenes components get "out of whack" for lack of a better phrase.  Do other Express VI's cause the same problem?  Also, if you create a task in MAX and save it, then place a task constant on your LabVIEW block diagram, select your task, right click on the constant and select "Generate Code", does it successfully generate LabVIEW code?
Seth B.
Principal Test Engineer | National Instruments
Certified LabVIEW Architect
Certified TestStand Architect
(3,176 Views)
