DAQ not working with stand-alone program
I am running LV8.6 and using a cDAQ 9172 with the 9234 module operating an Accelerometer.
The VI I created in LV works fine and compiles into an executable and will run just as well on the same computer with LV and DAQmx installed.
My goal was to build a program that could be installed on any computer, connect the DAQ and use it.
I created an installer which included LV and DAQmx runtimes, and installed my application to a computer that didn't previously have drivers.  The application won't display data from the accelerometer.
I opened  "Measurement and Automation" to verify that the DAQ is working properly.  Besides having to "Enable IEPE" to see anything, the DAQ appears to work fine.
Still no data displayed on my Application.
What am I missing?
(Also trying to keep entire installer smaller than a CD...)
ETA: This might be in the wrong forum.  Mods, feel free to move.
Message Edited by JohnatOIW on 04-22-2009 04:38 PM
(3,139 Views)
Well it would be intersting if you can add some error handling to your applikation to see whats going in in the executable.
Maybe its something simple that a Task Configuration from MAX is missing or the device specifire is wrong. But all this can be determined by looking at the error codes which might come up.
Christian
(3,115 Views)
