DAQ programming ...
Hi there ...
does anybody know, whether I can program the NI boards using the
DAQ libraries and a compiler different to LabView/CVI (e.g.,
Borland C++ Builder) ?
(4,203 Views)
Actually, we are trying to program our DIO 96 using Visual C++. Anybody have
any ideas?
(4,203 Views)
>Anybody have any ideas?
Hi Dan,
Not in C++, in C. Should not be too different:
#include "nidaq.h"
i16 status = 0;
i16 deviceNo = 1;
i16 portNo = 1;
i32 pattern = 255;
status = DIG_Out_Prt(deviceNo, portNo, pattern);
if (status < 0) {
printf("Ni-Daq error : %s", status);
Then compile. Dont' forget
"-Ic:\ni-daq\include" and "c:\ni-daq\lib\nidaq32.lib"
Similar for each other function (see also
help->index->DIO-24 and DIO-96 Device Function List)
Hope it helps,
Walter van Iterson
(4,203 Views)
I've used the NIDAQ api in a couple environments with success: Borland
Delphi 3 and VC++ 6. I suspect that Borland C++ Builder will not pose any
limitations. Look in \NI-AQ\Examples for a good starting point.
Chris Lincoln
ULTRAX, Inc.
"Gerwin Schalk" wrote in message
news:39c11f26@newsgroups.ni.com...
> Hi there ...
(4,202 Views)
I've been programming the NI5911 with NI-SCOPE in Borland Builder 4 for
some time now. Get in touch if you need help.
David Bell
Gerwin Schalk wrote:
> Hi there ...
(4,202 Views)
