DAQ selection
I need to select a usb powered low  cost daq to read an analog voltage upto 24V DC. Any suggestions please. Thank you!
Best Regards,
Dhans 😉
Kudos are welcome 😉
Aspirant Labview Programmer (Labview 14) 😉
(5,509 Views)
Hi dhans,
Thanks for your query. There are many factors to take into account when selecting hardware. I would recommend calling your local NI office to discuss your application needs so we can work together to select the most suitable hardware for your application.
Tom
(5,487 Views)
Thanks, Tom.
I have read a document from NI in which they have given enough details to choose a correct hardware.
Best Regards,
Dhans 😉
Kudos are welcome 😉
(5,485 Views)
In my experience, anything low-cost and USB powered will only read +/- 10Vdc.  You will need some sort of signal conditioner to scale the voltage down to this range and then you can scale it back up in software.
I don't know what your definition of low-cost is but I have used the USB-6212 in several applications and it works for what I am using it for.  There is a list of USB devices on this page.
aputman
(5,464 Views)
Thanks..Aputman.. I have found one compaq DAQ chassis and a DAQ card NI-9221 which can read an input voltage of -60V to +60V.
NI-9221 - https://www.ni.com/docs/en-US/bundle/ni-9221-specs/page/specs.html
C-DAQ - https://www.ni.com/docs/en-US/bundle/cdaq-9171-specs/page/specs.html
Best Regards,
Dhans 😉
Kudos are welcome 😉
(5,437 Views)
