DAQ task channel order (PXIe-4498)
I have a PXIe-4498 for which I programmatically generate an acquisiiton task.When the task is built the channel order is not necessarily in ascending channel number.
My question is whether the DAQ card will return the data in the order in which I defined the task or in channel order?
(4,325 Views)
Accepted by topic author Dave.M
It seems the answer is that the channels have to be specified in order when building a task.
(4,320 Views)
