DAQ wizards not recognizing PCI-6014
I'm trying to do some simple data logging and also a PI loop with 4-20mA out using a pci 6014. The assistants don't recognize my hardware. I've got the data logging running but am having trouble writing to the analog out (I'm planning to use an IC to convert the 0-10V to 4-20mA). The NI-MAX can write to the card OK as can some of the examples, however when I try to write to two channels at once using the examples I get an error. Also I can't change the AO-write.vi to accept a non-waveform data type.
Tom
(2,769 Views)
Tom,
The reason your board isn't recognized by the DAQ Assistant is because the DAQ Assistant uses NI-DAQmx functionality which currently is not compatible with the PCI-6014. You will have to use Traditional DAQ 7.0 or earlier.
As far as the errors you are receiving, can you be more specific as to the error #s and/or messages?
Hope this helps. Have a great day!
(2,769 Views)
Thanks for the tip. I think I can sort through the other issues.
(2,769 Views)
