DAQ
Is DAQ ADC data can aceess using any plaette if yes how
(3,115 Views)
Sorry, but I don't understand the question at all.
(3,106 Views)
If you are looking for the VIs that control DAQ cards, you'll need to install the NI-DAQmx driver after LabVIEW is installed.  Then, you will be able to find the VIs on the Measurements I/O » NI-DAQmx pallet.
For examples on using NI-DAQmx, please visit ni.com/gettingstarted.
Seth B.
Principal Test Engineer | National Instruments
Certified LabVIEW Architect
Certified TestStand Architect
(3,102 Views)
