DAQCard-6024E for win 7
can i use the DAQCard-6024E with win 7. which driver should i use?try with NiDaqmx for win 7 but get an error message
(4,176 Views)
You can only use the DAQCard-6024E on 32-bit OSes.  Are you using Win 7 32-bit or Win 7 64-bit?
From the latest DAQmx readme:
The following devices are supported in NI-DAQmx on the 32-bit versions of Windows 7/Vista. They are not supported on the 64-bit versions of Windows 7/Vista:
    * NI DAQCard-6024E 200 kS/s, 12-bit, 16 analog input channel, two analog output channel, 8 digital I/O line, two counter/timer device
    * NI DAQCard-6036E 200 kS/s, 16-bit, 16 analog input channel, two analog output channel, 8 digital I/O line, two counter/timer device
    * NI DAQCard-6062E 500 kS/s, 12-bit, 16 analog input channel device
    * NI DAQCard-6715 for PCMCIA 1 MS/s 12-bit analog output device
    * NI DAQCard-DIO-24 for PCMCIA 24-channel 5V/TTL/CMOS digital I/O device
    * NI SCXI-1600 USB module
Best Regards,
John Passiak
(4,149 Views)
Thanks to you.
I use win 7 64bit.
That's why it alwiz appear an error.
Best Regards,
(4,141 Views)
