DAQCard-6024E locks Panasonic CF-47 on boot
I'm trying to install the 6024E in a Panasonic Toughbook. I've loaded the accompanying software (NI-DAQ, MAX,). When I insert the 6024E and reboot, the laptop freezes at the blue NT boot screen. Any ideas?
(3,070 Views)
Troy,
My first suggestion would be to uninstall NI-DAQ and reinstall it. If you are not using the most recent version (6.9.3), you can download it from the following location:
NI-DAQ Version 6.9.3 for Windows 2000/95/98/ME/NT/XP
If this does not solve the problem, I would try installing the card in a different PCMCIA slot in the same computer and then in a different computer. This should help you to locate the cause of the problem (the PCMCIA slot, the computer, the card, etc.).
Good luck with your application.
Spencer S.
(3,070 Views)
Tu puerto pcmcia es reconocido por tu pc, Haz instalado otra tarjeta por ejemplo de moden o puerto serial en este puerto Carga el software de nI sin tener instalado la tarjeta en la ranura PCMCIA, reinicia la computadora con la tarjeta pcmcia instalada para que la reconozca Si tu pc tiene menos de 128 megas RAM el equipo se bloquea Saludos
(2,678 Views)
(2,677 Views)
