DAQCard-6062E returns time out after change of PC
can anyone help me? My DAQ Card-6062E always returns a timeout when logging data after I installed it in a brand new PC.
I use a PCMCIA-Adapter to connect the card to the PCI bus.
The card worked well with an older PC, which is no longer available, and the same PCMCIA Adapter. The operating system is Windows XP, the card driver is NI-DAQmx 8.3 or the traditional NI-DAQ 7.3, which I tried out after I was not able to get the data acquisition running.
With the NI-DAQmx driver I get the timeout error when I use the selfcalibration function in MAX.
With the traditional driver, when using the Test-Panels in MAX I first get a "Device not responding to first IRQ level" message, than when using the Test-Panels I get timeouts.
I want to acquire the data in Matlab with the DAQ-toolbox, but here I also get the timeout errors with both drivers.
When I install the card in a old laptop it works normally. Unfortunately the laptop is to old for logging in into our company network, therefore I cannot use it for my measurements.
Has anyone an idea what the problem could be?
Thank you very much!
Raphael
(2,979 Views)
Hello Raphael,
The problem is that not all PCMCIA-to-PCI adapters are tested with the NI-DAQ Cards. It is a known issue that not all adapters are compatible with NI-DAQ Cards and Motherboards. To avoid trouble the best is to use an adapter from Synchrotech.
More information you can find in this KnowledgeBase.
http://digital.ni.com/public.nsf/websearch/49CC0C97E26A2D5786256B13007C3047?OpenDocument
Further you should check this KB. Maybe it is a related problem.
http://digital.ni.com/public.nsf/websearch/B5D63EDC141548B586256ADF005553A2?OpenDocument
Best Regards,
Wolfgang
(2,964 Views)
Hello Wolfgang,
You were right, the problem was the PCMCIA-to-PCI adapter. After updating its driver there were no more problems with my data acquisition.
Thank You very much for Your help.
Raphael
(2,949 Views)
