DAQCard-700 And NT4
I try to configurate the DAQCard-700 on a Toshiba
Tecra 8000 running WinNt4 (SP4).
The problem is that I am unable to find the right
combination for the I/O address and the Interupt
number. In the Ni-DAQ 6.6.0 software, the say
that we have to try all combination possible.
There is too much combination to try. Is there a
trick to find the good combination for the
address and the interupt ?
Benoit Petitclerc, P.E.
Sent via Deja.com http://www.deja.com/
Before you buy.
(4,468 Views)
In article <7tvb7m$m5a$1@nnrp1.deja.com>,
> Tecra 8000 running WinNt4 (SP4)and a XIRCOM CEM56 Card.
> The problem is that as soon as the Xircom card is in the PC, the
DAQCard-700 doesn't work. The software return and message that the
device doesn't respond to the specified base address. Thes Xircom and
National Cards have no conflict in the interupt number and base address
configuration..
As soon as I remove the Xircom card from the Pc, the DAQCard works
perfectly.
> Thanks
> Before you buy.
Before you buy.
(4,468 Views)
