DAQCard 700 to buy
I have an application that require the DAQCard 700.
Do you have some of them to offer? I need a lot to have spare parts for some systems
(2,791 Views)
Gilles,
We don't sell that board anymore but we do have comparable boards that we do sell. For example, the DAQCard-6024E has 16SE/8DI analog inputs, 12 bit resolution, +/- 10V range, 200 kS/s, 8 DIO lines, and 2 counters. The only differences are the rate, # of DIO lines, and the 6024E has added analog outputs. Is there a specific reason you can only use the DAQCard-700? Hope this helps. Have a great day!
(2,791 Views)
I need a card that is pin by pin equivalent of the DAQCard 700 because this is already use in an instrument. At this time we do not want to invest more time to adapt a new card.
I am searching for surplus card on some of your clients. Do you have someone to point me?
(2,791 Views)
