DAQCard 700 under Windows XP
Does the DAQCard 700 works without problem under a program build with the ApplicationBuilder under LabVIEW 5.0.1 on Windows98 and running on Windows XP? What version of NI-DAQ would be required? TIA.
(3,133 Views)
Hello;
With Windows 98, as long as you build the executable using the same NI-DAQ version you have on the target machine (the machine that will run the executable), you should be ok.
Labview 5.0.1 is not supported under Windows XP. If you want to work with that OS, you need to upgrade Labview.
Hope this helps.
Filipe
(3,133 Views)
I have A DAQ card 6062E and i have porblems with the drivers because when I use labview the program alert me that The DAQ Card drivers aren't fron national instrument. How I configure my device, what kind of software I can use?
Thank you
(3,133 Views)
