DAQCard-AI-16XE-50 Device does not respond to 1st IRQ level in Windows XP
DAQCards AI-16XE-50 and 6024E give the error "Device not responding to first IRQ level. Do you want to continue?" under TestPanel in Max 2.2, NI-DAQ 6.9.3, on a Dell GX620 with a Ricoh RL/5C476 PCMCIA to PCI adapter. If I click yes, I see input on the graph, as if the card is working. The DAQCards work fine with the same adapter under XP on a no-name machine. The DAQCards get assigned the IRQ 19, which is the same as the IRQ which gets assigned to the CardBus Controller. There does not seem to be a way to change the IRQ assignments.
(3,160 Views)
Please view the KB:
http://digital.ni.com/public.nsf/websearch/066CAE594C0B44E886256A530058F06A?OpenDocument
Certain cardbus controllers no longer support ISA based interrupts. The only Dell that we know currently does not work is the Infinium, which uses a generic Microsoft Cardbus Controller. Do you know what Controller is used in the Dell you have?
(3,160 Views)
I have a similar issue with the DAQCard-AI-16XE-50 on the Dell Inspiron 5100. Max 2.2, NI-DAQ 6.9.3, "Device not responding to first IRQ level" error. The CardBus Controller is a TI PCI-4510, with drivers provided by Microsoft. I suppose that this Controller cannot support ISA-based interrupts, as well?
(3,160 Views)
