DAQMx Error for DigPulse.c
I am trying to execute an example program DigPulse.c using DAQmx/VisualC++.  The hardware used is USB-6009. The following error appears:
 DAQmx error: I/O type of the physical channels does not match the I/O  tyep required for the virtual channel you are creating
Physical Channel Name: Dev1/ctr0
Virtual Channel Name: Dev1/ctr0
I/O Type Required for Virtual Channel : DAQmx_Val_CO
Task Name: _unnamedTask<0>
Status Code: -200430
Could someone please help me in resolving this problem?
ST
(3,294 Views)
Hi Spectra,
The 6009 isn't capable of counter outputs.  Details can be found in this Knowledge Base article.
Luke
(3,277 Views)
