DAQPad-1200 'Device Not Responding to First IRQ Level' Using Windows XP
Under device manager, go to the properties for your card. Select the tab Resources. Deselect the option Use "Use automatic settings". Then select another settings that allows you to change IRQ to one without conflicts. Restar PC and try using your board
Message 11 of 14
(1,913 Views)
I had a Compaq Presario 2500 with TI Cardbus using a DAQCard 1200 using NIDAQ 6.9.3 . The patch fixed it. Thanks a million.
Message 12 of 14
(1,913 Views)
Windows 2000/XP uses a different IRQ designation system then 95/98/ME/NT. You cannot change the IRQ settings manually.
The patch mentioned above fixes the "Device not responding to first IRG level" problem.
Message 13 of 14
(1,913 Views)
The patch has solved my IRQ problem with an HP laptop however I have an Acer Travelmate 4220 that I need to use with DAQ 1200 and the same patch does not work.... can anyone advise ?
Using XP  service pack 2 and driver 6.9.3.
Message 14 of 14
(1,486 Views)
