DAQPad1200
Hello
Really I have problem with my DAQ 1200. I have a Lab program on Labview 3 which works with DAQ 1200 parallel port. The PC is an old one with HD 500 MB and OS win 3.1
Now I have to use this system (Labview, DAQ 1200 parallel port) in new PC with new OS (does not matter which one 2000 or XP). I succeed to run Labview 3 in XP, put DAQ 1200 is still unknown by XP. Every time when I run my laboratory program in Labview there is error ((the DAQ device is unknown or the driver does not support it)).
Please can somebody tell me what I should do, or the best solution to make DAQ 1200 parallel port work with new OS and continue working with my Labview 3. I tried with win 2000, but by add new hardware I do not found DAQ 1200 to install it and by XP the same problem.
Thanks a lot
(3,298 Views)
Hi Lab1994,
I have found a good troubleshooter that may help you with this problem.
http://www.ni.com/support/install/parallel/boardxp.htm
Once you have done this it should appear in your Measurement and Automation Explorer (MAX).
I hope this helps.
Any problems please don't hesitate to ask.
Kind Regards
Michael
NIUK Application Engineer
(3,274 Views)
