DAQmax output problem for sampling frequency 1000Hz
Hi All
I am using the NI product ADC (NI 9215 with BNC, High speed USB carrier Ni USB 9162) for acquisition of analog signal using LabView and after that the signals are written into a text file.
At the moment.I have generated the signal using function generator (let say 100Hz, time period 10ms) and passing through the ADC using LabView.
The problem is, after acquiring the signal through ADC, I am getting 100 sample per cycle i.e sampling frequency is 10,000 Sample/sec!!!
But, I tried lot to get 1,000 Sample/sec in the ADC out put.
Could you please give me some advice/idea how to get 1,000 Sample/sec in the out???
I attached here block and front diagram for your reference.
Kind regards,
Hasan
(3,329 Views)
It looks like you have the rate set to 10,000 Hz. Change that to 1,000 Hz like you want on the front panel and it should give you what you want.
Peter C.
(3,276 Views)
