DAQmx 9.3.5 return of autostart bug
Steps to reproduce.
  1. create a finite sample output task
  2. Commit the task
  3. write n samples per channel Autostart =TRUE
  4. wait for completion
Another write at this condition should execute normally with autostart Ture (Default) yet the write vi will return 0 in number of samples written and no error will be produced.  This has been reproduced by NI and I have observed it with LabVIEW 2011 DAQmx 9.3.5 with DO 1D Waveform and AO N ch N sample 2d dbl poloymorphic instances.  exact scope is under investigation.
Workaround:
explicitly stop your finite sample tasks prior to subsequent writes.
Message 1 of 1
(3,415 Views)
