DAQmx 9172/9477 modules lose PC connectivity
One other thing to look at is the code itself. Are you doing a lot of static lines in multiple tasks? I've had a few customers that were using lots of lines in lots of tasks and having problems. If you put all the lines in a single task, it resolved their issues. Is this the case with your applications?
Andrew
Message 11 of 40
(2,770 Views)
This is still a problem for us... A technician recently told me that he sees this issue regularly and cycles power to the 9172. We've not yet seen it mid-test, but if that happens once, it could get a lot of higher level management attention.
Has NI duplicated this in the lab and what's the status of the debug effort?
Message 12 of 40
(2,733 Views)
This was a bit of a confusing revalation, but after swapping everything in my test system in a very piecewise fashion, I was able to determine that it seemed to the be processor in the rackmount PC that couldn't keep up with the system.
I deduce that running 4 TS threads of my nature in parallel is placing a severe memory and CPU burden on the PC...
anyways, I swapped out a 1600MHz VIA embedded processor with 1Gb RAM for a 2160MHz Core 2 Duo with 2Gb Ram and have only had one problem since...
hope this info helps someone...
-Scott
Message 13 of 40
(2,730 Views)
This happens to us when the system is idle, not when it's active, at least that is the case so far... Do I need a PC that idles faster?
Message 14 of 40
(2,728 Views)
good question, I don't know to be honest with you.
I recalled that this system ran fine with my development PC attached to it which is an Intel core2 CPU 6700 @ 2.66GHz with 2GB ram...so as a final struggle to swim, I threw it back on the system and eveything was working again. then I threw the deployment rackmount PC back on and everything failed again with multiple 9172 and every combination of brand new/used 9104, 9477 and 9205 modules...
if you have a development PC that you used to construct your code and you can put in place as a quick A/B test, I would suggest it....but I don't know the silver bullet on this one.
-scott
Message 15 of 40
(2,725 Views)
Would someone from NI R&D or PRODUCT SUPPORT please respond. THANKS. DAVID
Message 16 of 40
(2,723 Views)
Hello David,
This issue has been narrowed down specifically to HP computers.  Unfortunately the root cause has not been narrowed down. This issue has been filed under Corrective Action Request (102633) and is being looked into.  For right now, the best option we have is to manually reset your 9172 when your computer resets, or other users have fixed the problem with a PCI-USB card (I would recommend one with the NEC or VIA chipsets, NOT the ALI) which cost ~$20.  Thank you for your patience in this matter.
ColeR
Field Engineer
Message 17 of 40
(2,713 Views)
I am having the same issue with a Dell desktop. As this issue been resolved?
Ed
Message 18 of 40
(2,542 Views)
Ed, this issue has been resolved as of DAQmx 9.0.1 according to the Readme.
http://ftp.ni.com/support/softlib/multifunction_daq/nidaqmx/9.0.2/readme.html
Doug Farrell
Solutions Marketing - Automotive
National Instruments Automotive Solutions
Message 19 of 40
(2,507 Views)
This is happening on a Dell with DAQmx 9.0. I'm going to see if there are any Dell bios or usb driver updates that my help.
Ed
Message 20 of 40
(2,494 Views)
