DAQmx Analog output gets "Missing input" when Programmatic Input is selected.
I am trying to create a sequence where a square wave signal is passed programmatically to an analog output. I am using USB-6008 DAQmx and LabView SignalExpess 3.5.0.
In either Continuous, N samples or 1 sample (On demand) the DAQmx generate analog output step complains about missing input.
How do I configure the sequence to have the square wave signal to appear on the output?
(4,426 Views)
I tried using continuous samples and was able to specify the square wave signal as an input to the generate signal step.Now I am getting the following error:
Measurements: Requested value is not a supported value for this property.
Property: SampTimingType
You Have Requested: Sample Clock
You Can Select: On Demand
(4,422 Views)
Can you attach your SignalExpress project?  The USB-6008 supports hardware timed analog output, so you should be able to choose something other than On-Demand timing.  Just for clarification, you were able to generate an analog square wave and use continuous generation but not with a sine wave?  Lastly, are you using SignalExpress LE or the Full Version?
Todd V
NI Prototyping Community
(4,406 Views)
The 6008 does NOT support hardware timed analog output. You can only specify a single point at a time. This will restrict you to software timed output of a low frequency and considerable jitter.
(4,402 Views)
Hi Dennis,
You are correct, the 6008 does not support hardware-timed analog output.  The data sheet specifies a maximum output rate of 150 Hz, which led me to believe that it could support continuous generation at that rate.  As this KnowledgeBase indicates, this device can accept software-timed updates of up to 150 samples per second.
Todd V
(4,398 Views)
Thanks Todd,
I am using the full version of SignalExpress. I have not tried to use the sine wave because it's not useful for our purposes.
I got the error that Requested value is not a supported value for this property prompting to select on demand when I tried to use the continuous samples setting.
(4,384 Views)
As Dennis indicated, you got this error because the 6008 doesn't support hardware timed analog generation.  This is outlined in this KnowledgeBase article.  The DAQ advisor at ni.com/daq can help you find a hardware timed analog output device.  I apologize for the inconvenience.
Todd
(4,357 Views)
