DAQmx Base for LabVIEW 8.2
Will there be a new version of DAQmx Base released with built in support for LabVIEW 8.2?
(3,630 Views)
Hello Njg,
We always strive to stay current with our drivers. NI DAQmx Base 2.0.1 was released and included support for LabVIEW 8.0 and 8.0.1 and now that LabVIEW 8.20 is released, I expect to see a release of DAQmx Base that will have support for 8.20. Meanwhile, you could always copy the instrument files from the 8.0 directory to the LV 8.20 directory to use the DAQmx Base VIs from within LabVIEW 8.20. You will have to Masss compile the DAQmx Base directory in LabVIEW 8.2 once you copy the folders to the 8.2 directory.
Best Regards,
Ayman K
(3,594 Views)
We recently released NI-DAQmx Base 2.1 which includes support for LabVIEW 8.2.
(3,524 Views)
