Will NI-DAQmx Base for the PDA work when not using LabView? I have a custom application using the DAQCard 6036e and I am having trouble with the driver. I am being told to use DAQmx Base, but it appears to me this only works on the PDA if you use LabView, which I do not.
Can anyone tell me how to install (if possible) NI-DAQmx Base on a Windows CE platform that is NOT using LabView?
Justin Allen
Utz Tech LLC
