DAQmx Compatibility with NI max
I am trying to read signal from NI9202 DAQ but when I create the task I get an error which I have attached below.
LabVIEW version:17.0.01
NI Max:17.5
DAQmx: 17.6
The DAQmx drivers installed at the start were 17.5 but then I figured out that in order to run NI9202 I need to upgrade the driver to 17.6. When I had 17.5 driver I got an error saying 'Unsupported Hardware'. But when I installed the 17.6 driver I was able to see the NI9202 DAQ name.
One solution I tried was to remove the DAQmx driver and install it again, after installation gave out the same error.
Second solution I attempted was to uninstall and reinstall everything including all packages still gives out the same error.
I need help.
Thank you.
(2,218 Views)
Accepted by topic author Mak_2496
First thing I would do is reboot the computer.  If it is still broken, I would update DAQmx to 20.7 (the last version to support LabVIEW 2017 per NI-DAQmx and LabVIEW Compatibility).
(2,188 Views)
Which cDAQ chassis are you using?
(2,183 Views)
Thanks, Installing the latest version of DAQmx compatible with the LabVIEW version helped. I was trying the older versions and that's why I was having the issue.
(2,162 Views)
NI cDAQ -9174
(2,160 Views)
