DAQmx - Device identifier is invalid.
DAQmx Create Channel (DO-Digital Output).vi:1
Device Specified: 0
Suggested Device(s): Dev2, Dev1
Task Name: _unnamedTask<9>
This is the error message I am getting the first time I am trying to communicate to my instruments.
I am using a PCI-6221 & PCI-4462.
I have the Device names defined in MAX ( Dev1 & Dev2), and when I initialize my station, comms are fine...
Any suggestions??
Message 1 of 10
(9,240 Views)
Hi Jauron,
How are you trying to communicate with these devices?  It looks to me like you have a device specified as Dev1 and Dev2, but you are trying to communicate with device 0.  In your creat Digital Output Channel function, what are you specifying for the input "line"?
Let us know and we will definitely help you get up and running!
Message 2 of 10
(9,212 Views)
Thanks for the reply Ben.
I was able to solve the problem. I had a bas Class Virtual library, and was able to replace it, and everything works now.
Message 3 of 10
(9,201 Views)
I am facing same problem,
Error -200220 occurred at DAQmx Create Channel (DO-Digital Output).vi:2
Possible reason(s):
Device Specified: Dev2
Suggested Device(s): Dev1
Task Name: _unnamedTask<2>
New to Lab View..I am switched to new PC...
Please tell me solution for this???
Message 4 of 10
(8,949 Views)
The simplest thing to do would be to simply try to use dev1 instead of dev2 - exactly what the message suggests.
Your post contains so little information that any more help is next to impossible.
Message 5 of 10
(8,930 Views)
Open up MAX.
Clean up or rename devices you're not using.
In general, hard-wiring DAQmx devices to a specific Dev# can be problematic when moving machines or replacing DAQs.
I try to do an auto-scan and pick the appropriate model through property nodes rather than hard-code it.
Message 6 of 10
(8,928 Views)
The screen shot of MAX
Message 7 of 10
(8,908 Views)
Hi SnowMule,
How to do an  auto-scan and pick the appropriate model through property nodes???
Message 8 of 10
(8,891 Views)
Everyone knows what the error message is. Posting it twice is just a waste of time. You still have not mentioned what is generating the error. We don't know if its a task in MAX, a constant on a block diagram, or what. Changing any of these from dev2 to dev1 is a trivial matter but you need to provide more information than just a plea for help.
Message 9 of 10
(8,889 Views)
@hendr031 wrote:
Hi @SnowMule,
Get a DevNames array from the DAQmx property node.
Use an indexed loop to pluck the Product Type out, and compare it to the device you're looking for.
Message 10 of 10
(8,884 Views)
