DAQmx Express VI is searching for Configure DAQmx Assistant.vi
I have a system with a DAQ PCI6229 card. To readout data from it I use the DAQ express vi. This works well.
Now I would  apply this VI on another PC. To do this I have simulated a DAQ device in MAX. But when I start the VI LabView generate an block diagramm error. The message is SubVI DAQ Assistant: SubVI is not executable. When I will start the express VI it will surch to Configure DAQmx Assistant.vi, but I can't find this VI. What can I do to solve this?
Best regards
Wolfgang
(3,459 Views)
Hello Wolfgang,
I don't fully understand your construction. could you please send this VI to me?
Please check, if your SubVIs are all there.
Do you have DAQmx driver installed on this computer?
Maybe the wrong DAQ driver ist installed (that would explain why you can simulat in MAx but not use the VI inLabVIEW). Please post both, your DAQmx driver version, and youLabVIEW version here.
Check this Link, to see if your Versions comply:
http://digital.ni.com/public.nsf/websearch/97D574BB1D1EEC918625708100596848?OpenDocument
The DAQ Assistant gernerates a VI (code) that refers to the device you chose in the configuration of the ExpressVI (after configeration it creats a VI that fits you Parameters.) so you can't use the Express VI with an other identifier(name).
Also please give more detail on the error.
Greetings, Alex
(3,428 Views)
