DAQmx Reset Device Error in executable
Hello all
I am having a wierd error. I have a Win 10 operation system ( with normal User account i.e no admin rights) with LabVIEW 2016 installed on it. One of my VI have a "DAQmx reset Device.VI".
The whole project is saved in an external Server. When i run the whole project in Development environment, everything works fine. But when i create an exe file and run it from Server, it shows an error message " DAQmx Reset Device.vi: 4740001<append>.
And more funny is that when i copy the whole project to a Folder on to the computer ( i.e not from Server) and try running it in Development environement and exe, both works fine.
I tried
  • removing DAQmx 16 and installed DAQmx 15--> no success
  • resetted NI MAX configuration data --> no success
I could not find any other hints also as the error message does not provide any further details. Could it be something with admin rights to access
Does anyone have any idea?
Nghtcrwlr
Nghtcwrlr
(3,403 Views)
Were you able to resolve the issue?
Could you describe a bit more what do you mean by server? Is this some remote machine?
Best Regards,
TK
Certified LabVIEW Architect (CLA)
(3,319 Views)
No. I could not find any solution. At the moment i have copied the whole project locally and run it locally.
By Server i mean, a Network drive.
Nghtcwrlr
(3,313 Views)
