DAQmx Stop Task doesn't seem to stop a task...
In my application I'm using a Functional Global Variable for all Task-related operations.  I create a task, then I start it, then I read from the DAQmx buffer and everything works fine.  Then I stop the task and the task doesn't seem to stop.  I first saw this problem when I tried to restart the task and I got a message saying the task was reserved.  So then I tried stopping the task and then waiting till the task was done (constantly reading the Done? boolean on the DAQmx Task property node).  The task never got done UNLESS I placed a breakpoint somewhere (probably right before the property node), stopped at the breakpoint, and continued.
Should I be doing something else BEFORE I stop the task (like reading all samples from the buffer)?  I thought I had somehow solved this problem a while ago, but I was mistaken.  I first saw this with a USB9215A, but I'm now seeing this with a simulated E-series DAQ.
Thanks!
(3,222 Views)
I found the problem.  I was doing a DAQmx Read after running the DAQmx Stop.  I was expecting the DAQmx Read to generate an exception, however it was actually reading data.  I thought this was because the task hadn't stopped.  I just realized that the DAQmx Read is RESTARTING the task!
Thanks!
(3,212 Views)
Hey 2and4,
I am glad you found a solution and thanks for posting it!
Chris Delvizis
(3,192 Views)
