DAQmx USB Slow to configure
I am using the new USB-6009 devices in an application that fires off a thread for data acquisition.  The application runs mostly OK,  getting proper measurement times when it is running.
It takes up to 75 seconds to configure though!!!! (depending on machine and how many times it has configured)
I am using standard code
DAQmxCreateTask()
DAQmxCreateAIVoltageChan()
DAQmxCfgSampClkTiming()
DAQmxStartTask()
DAQmxReadAnalogF64()
DAQmxStopTask()
Is there anything I can do to get rid of this delay?  It seems to be the initial CreateTask() and the CreateAIVoltageChan() that are the delays.  This never was a problem with Traditional DAQ and an E-Series board.
Thanks for your help
(3,140 Views)
My NI 6008 needs 11 seconds to initialize
Win 2000, 256MB, 1,2GHz
Greets
Dubin
Grüsse aus Deutschland
(GMT +01:00)
(3,129 Views)
Hi Wayne,
I would first check to see if you can run the examples that install with the driver without this delay.  If there is no configuration delay when running the examples, there may be some conflict within the program you have written.  If the examples also show this delay, then try with another computer or another USB-6009 if you can because that seems to point to a hardware issue.  Does the time vary at all with the number of channels you are configuring?  You could also try creating global channels in Measurement and Automation Explorer (MAX) and programmatically adding them to your task using DAQmxAddGlobalChansToTask to see if you get a reduced configuration delay.
Let us know if any of this helps!
Laura
(3,105 Views)
