DAQmx and State Machine
Hey all,
I am developing a State Machine in which I need to run four different tasks
1. Generating a Analog Output Voltage
2. Generating a Digital Output
3. Generating a Continious Digital Train pulse (using DAQmx CO pulse freq) -Problem is with this part
4. Counter Read Operation (using DAQmx CI cnt Edges
First I have Designed seperate VI's for the Tasks and everything is working fine but when I Designed a State Machine the third Task(Generation of Digital Train Pulse) is not Working. I am not able to find the problem
  My DAQ device is USB-6351, ANY help would be greatly appreciated.
I am attaching the Project File of my State Machine and separate VI which Includes code of Tasks 3 and 4
Please let me know if you need any sort of additional information from me to understand what I am doing.
(2,476 Views)
Can you describe what issue or error you are facing with the counter APIs. Please elaborate what do you mean by "not working". I would also like to know whether you are able to write other signals other than the pulse train.Thanks!
(2,415 Views)
