DAQmx base USB-9233 in windows CE
The DAQmx Base Documentation says that USB-9233 is support, but it does not have the tools for configured de external source and other things of this module. So what i have to do for work with this module in windows CE 5.0?
Regards
Oscar Molina
(4,257 Views)
Well, what exactly is it that you want to do? Have you programmed with DAQmx Base before? If so, have you done it on Windows CE 5.0? In order to use the 9233, you need to have the USB carrier; do you have that?
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(4,247 Views)
Ok. To development the application, I use the national instrument mobile module of LabView, so the objective is to make a portable system for measurement sound and vibration.
In addition I have worked with DAQmx over Lavbiew, but not DAQmx base.
Finally I have the USB carrier, and the system whit Windows CE has installed the DAQmx base drivers.
Regards
Oscar Molina
(4,243 Views)
Great! I am sure you have installed the latest version of DAQmx base on the machine. After running the NI-DAQmx Base installation, you must copy the driver
files to the device. Complete the following steps to run the Pocket PC Driver Installation utility:
1. Select Start»Programs»National Instruments»NI-DAQmx Base»Utilities.
2. Launch the Driver Installation utility that corresponds to your device.
3. Check the device screen to see if any additional steps are requested, such as replacing an older driver.
If there are no error messages, you have successfully completed the steps to install the driver files on the device.
Then open up LabVIEW and try running an example program for DAQmx base and PDA.
Adnan Zafar
(4,239 Views)
In reality, the installation of driver was not the trouble, the trouble is that I don’t found an example, over mobile module of LabView and uses DAQmx Base, and I don’t found how configure the 9233 module like the way used DAQmx whit property nodes
Regards
Oscar Molina
(4,235 Views)
Look over here and you should be able to find examples:
Where Can I Find NI-DAQmx Base Examples?
Once you do that, try to make them work for the 9233. If you face any problems, be sure to post back.
Adnan Zafar
(4,231 Views)
