DAQmx error -50526
I' trying to test nidaq with Borland C++ and as I compile my program I always have the same error:
Status code -50256
The specified feature has not been implemented for this environment. The operation could not be completed as specified.
This error is present if i test the analogical entries in the NI9215. I already tested the 8.3 lib and the problem persists.
I'm using DAQMX Software version 8.3 and windows vista could the problem be the operating system (Windows vista)???
Thank's for the help.
(3,363 Views)
DAQmx 8.3 don't support Windows Vista.
You can use DAQmx 8.5.
Regards
VéroniqueD
NI France
(3,348 Views)
Problem Solved.
I installed DAQmx v 8.5
Thank you very much for the tip VéroniqueD.
(3,341 Views)
