DAQmx not displaying readings from multiple channels
I am trying to acquire temperature readings from 3 consecutive channels using a DAQmx task as shown in the attached pic.
I have a producer-consumer loop for quick reading and writing of the samples to a file.
To specify the channels, I have typed into the box wired to the 'physical channel' terminal (not shown in pic) as follows - SC1Mod2/ai2:4.  This is to acquire readings from analog channels 2,3 and 4. The program should then write readings from all 3 channels to a file.
The code works perfectly if I am acquiring samples from 1 channel only.
When I try to acquire from multiple channels, I can only see readings on one of the numeric indicators wired to the acquisition task.
I would appreciate any inputs on what might be wrong with the code.
Thank you.
(4,110 Views)
The broken wire seen in the pic is a result of adding multiple channels to the acquisition task.  I managed to get around that by specifying a different data type but even with an intact wire, the program doesn't display readings from the remaining 2 channels.
(4,102 Views)
You need to change your queue data type to be an array of doubles.
(4,086 Views)
Accepted by topic author kumv10
Instead of using the To Dynamic Data Type and then Split Channels, just use an Index Array to get your three values.
(4,085 Views)
Thanks! Works perfectly.
(4,071 Views)
