DAQmx stops working after 4+hrs
I have an exe that primarily reads 32 TCs from an SCXI and also sets the current temperature.  The vi worked fine but, the exe went "not responding" after a little over 4 hours of holding a temperature.  from the saved data it appears after the failure the temperature slowly went down over time until this morning when it was checked on and the exe was locked up.  I assume it is a problem with DAQmx since software/hardware I/O issues typically have this symptom.
(3,676 Views)
It's more likely a problem with your program. Please attach the VI.
(3,663 Views)
