DAQmx write Function Generator
I am trying to write a very simple labview program to play a sin wave on my PXI 6723 card. I am trying to use the DAQmx Create Channel (AO-FuncGen).vi to do this. However, I get an error message below:
Error -200432 occured at DAQmx Create Channel (AO-FuncGen).vi
Selected physical channel does not support the output type required by the virtual channel you are creating.
Create a channel of an output type that is supported by the physical channel, or select a physical channel that supports the output type.
Property: AO.OutputType
You have requested: Function Generation
You can select: Voltage
The error message is quite clear! But I don't understand why my PXI 6723 Ao0 channel doesn't support that operation. Can someone explain.
Paul
(6,494 Views)
That board's not an NI function generator is it? I think it's just a analog output board. In which case you have to select Analog Output>Voltage as the type.
(6,478 Views)
hi,
you are right, it is just an analog output board. But I thought the function generators use the FGEN driver and not the DAQmx driver? Do you know which boards support this DAQmx function?
thanks,
paul.
(6,453 Views)
That task type was added for as yet unrealesed products. It may be expanded to add support for additional DAQmx AO devices in a future driver release. For your application, take a look at the LabVIEW shipping examples -the Cont Gen Wfm Int Clk example is a great place to get started.
hope this helps,
Andrew S
(6,450 Views)
I have a similar problem. I am using the PXI-6229 card to generate a function (sine) on analog output channel. I am getting the same error message. What could be the issue?
Kindly let me know.
Priya.
(6,238 Views)
The issue is exactly what is explained already. You don't have an FGen board and cannot use AO FGen. What part of the answers do you not understand?
(6,233 Views)
