DAQmx
What happened to DAQmx vi's when I installed NIDAQmx 8.9.5 over 7.1 full dev system?  All my DAQmx create, read, clear, etc., vi's are gone.
(3,120 Views)
DAQmx 8.9.5 does not include LabVIEW 7.1 support.  When installing a new version of DAQmx, the installer first runs the uninstaller of the previous version, which removed support in LabVIEW 7.1.  If you need DAQmx support in LabVIEW 7.1, please uninstall DAQmx 8.9.5 and install DAQmx 8.9.
Seth B.
Principal Test Engineer | National Instruments
Certified LabVIEW Architect
Certified TestStand Architect
(3,116 Views)
