DAQmxAOCreateFuncGenChan
wir wollten die aus der NI-DAQmx C Reference Help kopierte Funktion ""DAQmxCreateAOFuncGenChan"" nutzen, aber wenn wir Sie in unser Programm einbinden, gibt es diesen Aufruf nicht in der NIDAQmx.tlb. Wir haben eine PCIe-6361 Messkarte im System unter Visual Basic 6, Win XP SP3.
Danke für Eure Hilfe!!!!
we would like to use the function ""DAQmxCreateAOFuncGenChan"" which we found in the C Reference Help of NI-DAQmx. Unfortunately this call is not found in the NIDAQmx.tlb. We are using the PCIe-6361 under Win XP SP3 and we are programming in Visual Basic 6 SP6. Can anyone help us / give us a hint?
Thanks in advance!!!
Axel
(3,451 Views)
Accepted by topic author Linde
Hi Alex,
it's a mistake in the documentation that the NI-DAQmx C API and Visual Basic 6.0 Reference are the same.
For generating a waveform use DAQmxCreateAOVoltageChan instead in Visual Basic 6.0.
Best Regards,
Jan
(3,378 Views)
Thanks for your reply, Jan, though that is not what I wanted to hear...  😉
I saw the function "DAQmxCreateAOVoltageChan" and last night I tried to make it work. What I don't understand is the setting of the frequency. The NI example doesn't work, because in Europe we don't use the dot as a decimal point. So I integrated a Val() and that helped, but the Freq from the default setting is not what I see on then Analog Output. There is a factor 100 that I don't find. Is the 100 Hz setting something for an internal clock rate? I want a function, where I can set frequency and amplitude (zero to peak oder peak to peak) and eventualy offset and the AO makes it. What relation do I have to set between Buffer size, No of cycles and so on? But this is a new theme that I will post.
Thanks for your helpful answer,
Axel
(3,376 Views)
