DAQmxBaseReadAnalogF64 on Linux returning no samples
I am trying to solve a mystery. I have a PCI 6220 board installed in a linux PC running OpenSUSE 12.2. When I compile and run my test program and try to read in samples the DAQmxBaseReadAnalogF64 returns 0 for success but a samplecount of 0.
If I install the card in a Windows 7 PC using DAQmx (nor base) everything runs perfectly and I get samples as expected.
I also tried the NI example programs, but these also return no samples.
My assumption was NI drivers, so I tried to uninstall and reinstall the drivers, rebooted and then tried again -  Same result.
Have I missed something obvious or any suggestions?
The basic source code as follows:
bool
do_initialise()
        XString        s;
        m_nchannels = 16;
        m_device = "Dev1";
        m_maxSampleValue = 10.0;
        m_sampleRate = 8000;
        m_samplesPerCallback = m_sampleRate / 10;
        m_dataBufSize = m_nchannels * m_samplesPerCallback;
        float64        *pFloatBuf=new float64[m_dataBufSize];
        m_databuf = pFloatBuf;
        return true;
bool
do_open()
        m_openflag = false;
        x_int32_t    r=0;
        r = DAQmxBaseCreateTask("", (TaskHandle *)&m_handle);
        if (r >= 0)
            for (int i=0;i<m_nchannels;i++)
                XString        channelname;
                channelname.format("%s/ai%d", m_device.c_str(), i);
                r = DAQmxBaseCreateAIVoltageChan((TaskHandle)m_handle,
                                            channelname,
                                            DAQmx_Val_RSE,
                                            -m_maxSampleValue,
                                            m_maxSampleValue,
                                            DAQmx_Val_Volts,
                                            NULL);
                if (r < 0)
                    // log error
        else
            // log error
        if (r >= 0)
            // Our output blocks are in 1/10th second
            // Out input frequency is fixed at 8000Hz
            // So request 800 samples!
            r = DAQmxBaseCfgSampClkTiming((TaskHandle)m_handle, "", 8000.0, DAQmx_Val_Rising, DAQmx_Val_ContSamps, m_samplesPerCallback * m_nchannels * 10);
            if (r < 0)
                // log error
        if (r >= 0)
            r = DAQmxBaseStartTask((TaskHandle)m_handle);
            if (r < 0)
                // log error
        if (r >= 0)
            m_openflag = true;
        else
            DAQmxBaseStopTask((TaskHandle)m_handle);
            DAQmxBaseClearTask((TaskHandle)m_handle);
        return m_openflag;
bool
do_close()
        m_openflag = false;
        return true;
bool
do_onDataReady()
        float64    *data=(float64 *)m_databuf;
        int32    samplesread=0;
        int        r;
        r = DAQmxBaseReadAnalogF64((TaskHandle)m_handle, m_samplesPerCallback, 10.0, DAQmx_Val_GroupByChannel, data, m_dataBufSize, &samplesread, NULL);
        theAppLog.debug("After DAQmxReadAnalogF64 r=%d, samplesread=%d", r, samplesread);
        return true;
int
main()
        bool    ok=true;
        if (ok) ok = do_initialise();
        if (ok) ok = do_open();
        for (int i=0;ok&&i<100;i++)
            ok = do_onDataReady();
        if (ok) ok = do_close();
        do_shutdown();
(4,473 Views)
Hi Simon,
Have you seen these papers on working with DAQmx in Linux?
"Programming Data Acquisition for Linux with NI-DAQmx Base"
"NI-DAQmx for Linux Frequently Asked Questions"
Regards
Art
(4,419 Views)
