DAQmxCfgDigPatternRefTrig on an Analog Input Task
I am running an analog input task on a PCI-6115 card that I would like to reference trigger with a digital pattern trigger.  My programming environment is Borland C++ Builder using the Text Based code from Ni-DAQmx 9.5.1.  And, even though C++Builder is not officially supported, it ships with a routine that can convert the DAQmx.lib to a usefull format.  All of the other functions work as expected.
Once the task is created, several channels are successfully added using:
EC (DAQmxCreateAIVoltageChan ( RefTrigtask, .......));
The next operation defines the reference trigger for the task with:
EC (DAQmxCfgDigPatternRefTrig (RefTrigtask, “dev1/line0:7”, X0FER1EF, DAQmx_Val_PatternMatches, 500000));
This function trips with error code -200077 and the extended error text:
Requested value is not a supported value for this property.  The property value may be invalid because it conflicts with another property.
Property: DAQmx_Ref_Trig_Type
Requested Value: DAQmx_Val_DigPattern
You can select: DAQmx_Val_AnlgEdge, DAQmx_Val_AnlgWin, DAQmx_Val_DigEdge, DAQmx_Val_None
All of the documentation provided in the NI-DAQmx Help files suggests this should work along with all the other reference trigger methods.
Am I doing something wrong?  Could this be a bug, or is this simply not supported by this card?  Has anyone else ever tried it?
(3,459 Views)
Accepted by topic author grude
Hello Grude,
The error you are getting and the lack of documentation on this feature in the S series user manual, and 6115 specifications point to the fact that Digital Pattern Reference Triggers are not supported on the 6115. If you are looking for this functionality I would point you towards 6535 or 6536 but I do not believe these cards fit your desired application (assumption based on the snippet of code below) of reading an analog signal.  Thus, I suggest you recreate this feature in software by polling the state of the lines for the pattern you are looking for, or in hardware by using the cards I mentioned above which support Digital Pattern Reference Triggers and export the trigger to the 6115.
Izzy O.
Applications Engineer
National Instruments
ni.com/support
(3,440 Views)
