DAQmxCreateAIVoltageChan and DAQmxSetChanAttribute
We are implementing a DAQmx task with PXI-6255 and see alot of noise on a NRSE channel.  All the other channels in the task are created as RSE channels.
For the NRSE channel we first create the channel as follows:
DAQmxCreateAIVoltageChan (taskHandle, phyChan, virtChan, DAQmx_Val_RSE, 0,10,
     DAQmx_Val_Volts, NULL);
Then later on we set the terminal config using DAQmxSetChanAttribute:
DAQmxSetChanAttribute (taskHandle, phyChan, DAQmx_AI_TermCfg, DAQmx_Val_NRSE);
Do we need to use virtChan name in the DAQmxSetChanAttribute to ensure we get NRSE configuration?  We don't see an error when using phyChan name.
THanks in advance.
(4,924 Views)
Hi jharris66,
This sounds to me like a grounding issue. Is your signal source floating or grounded? Please reference the following resource for wiring best practices:
https://www.ni.com/en/shop/data-acquisition/measurement-fundamentals/field-wiring-and-noise-consider...
David H.
(4,893 Views)
