DAQmxGetDevAIPhysicalChans function and PXI devices
Hi
I have problems with DAQmxGetDevAIPhysicalChans function and PXI device. When I want to indicate available analog inputs of the device which is not a PXI device everything works fine, but when it is PXI device the DAQmxGetDevAIPhysicalChans function doesn't give any result.
Changing the name of the PXI device from default given by MAX "PXI1Slot2" to for example "PXI" or "Dev1" solve the problem, but as far as I am concerned this function should indicate available AI regardless of the device name in MAX( of course taking into account some restrictions about device name - no space, or other signs).
I must add that I'm using simulated PXI devices and NI-DAQmx 8.0.1 with Visual C++ 6.0 without Measurement Studio
Have anyone the same problem and solve it?
Best Regards
Lukasz Czuchaj
(3,582 Views)
Hello Lukasz,
I've tried this within LabVIEW using the analogous property node with the latest version of the NI-DAQmx driver (8.3) and seen no issues.  I'd be happy to try it in Visual C++ if you can attach some sample code that you are using to test this.
Travis G.
Applications Engineering
www.ni.com/support
(3,570 Views)
Hi Travis
Thank You for replay.
You are right there is no issue, it was my mistake. I have made the data and bufferSize to small in DAQmxGetDevAIPhysicalChans function.
"The darkest place is under the light" 😉
(3,562 Views)
