DAQmxReadAnalogScalarF64() function never returns.
I am using an NI USB-TC01 device for reading Temparature, with a library version  NI DAQmx 21.3.0 on Windows.
The DAQmxReadAnalogScalarF64() function is used to read one sample, the code will run for few hours, giving proper temparature readings. But later after a few hours of successful run when the DAQmxReadAnalogScalarF64() is called, it gets stuck and this function never returns a value nor an error code.
Apparently my code sample looks like this :
puts("NIDevice...DAQmxReadAnalogScalarF64 calling");
signed long _Errorcode = DAQmxReadAnalogScalarF64(m_taskHandle, 10.0, &val, NULL);
puts("NIDevice...DAQmxReadAnalogScalarF64 completed");
I can see the last output as : ...NIDevice...DAQmxReadAnalogScalarF64 calling
Please let me kow if you need more information
Regards
MSA
(1,454 Views)
Hello MSARAT, Can you send me the whole code?
(1,392 Views)
