DAQmxRegisterDoneEvent
I am using the RIO-9215 with DAQmx and VB6.  I am attempting to digitize a second of data and would like to use DAQmxRegisterDoneEvent to catch the end of the digitizing process.  I am using the code below.  The code works with no errors when the comment is removed from the call to my DAQDone sub which contains .  But when it is in place the event sub never fires and DAQDone is never called.  All of this code is in a single .BAS module.
Anyone have an idea what I am doing wrong?
Sub DAQStart()
    Dim n As Integer
    Dim NumChannels As Long
    Dim ChanNumberString As String
    'Create the DAQmx task.
    DAQmxErrChk DAQmxCreateTask("", TaskHandle)
    ChanNumberString = ""
    For n = 0 To DAQChnl - 1
        ChanNumberString = ChanNumberString & "Dev1/AI" & DAQMsg(1, n) & ","
    Next n
    ChanNumberString = left(ChanNumberString, Len(ChanNumberString) - 1)
    If KillIt Then Exit Sub
    'Add analog input channels to the task.
    DAQmxErrChk DAQmxCreateAIVoltageChan(TaskHandle, ChanNumberString, "", _
                DAQmx_Val_Cfg_Default, -10, 10, _
                DAQmx_Val_VoltageUnits1_Volts, "")
    'Configure task for sample acquisition and read in data
    'int32 DAQmxCfgSampClkTiming (TaskHandle, const char source[], float64 SampleRate, int32 activeEdge,
    '       int32 sampleMode, uInt64 sampsPerChanToAcquire);
    DAQmxErrChk DAQmxCfgSampClkTiming(TaskHandle, "OnboardClock", DAQSampleRate, DAQmx_Val_Rising, _
                DAQmx_Val_AcquisitionType_FiniteSamps, DAQSamples)
    DAQmxErrChk DAQmxGetTaskNumChans(TaskHandle, NumChannels)
    DAQArraySize = DAQSamples * NumChannels
    ReDim Data(DAQArraySize)
    DAQmxErrChk DAQmxRegisterDoneEvent(TaskHandle, 0, AddressOf DAQmxEvent, Null)
    DAQmxErrChk DAQmxStartTask(TaskHandle)
    'DAQDone
End Sub
Public Function DAQmxEvent(TaskHandle As Long, Status As Long, Data As Long) As Long  '#ErrLinesDone#
    Stop
    DAQDone
End Function
Public Sub DAQDone()
    Dim VoltBuf() As Double
    ReDim VoltBuf(DAQArraySize)
    'Get the data from DAQ
    DAQmxErrChk DAQmxReadAnalogF64(TaskHandle, DAQmx_Val_Auto, 10#, _
                DAQmx_Val_GroupByScanNumber, VoltBuf(0), DAQArraySize, DAQSamples, ByVal 0&)
    'Task is done so clear it.
    DAQmxErrChk DAQmxClearTask(TaskHandle)
    'Format data into the DAQData(Chnl, Sample) array.
    '... more stuff here
    'Clear unused array.
    Erase VoltBuf
End Sub
(3,596 Views)
Hello Peek,
The problem may be with the way you are setting up the DAQmxEvent callback function.  The NI-DAQmx C Reference Help says that the callback function you pass as a parameter to DAQmxRegisterDoneEvent must have the following form:
int32 CVICALLBACK Callback (TaskHandle taskHandle, int32 status, void *callbackData);
Admittedly, I'm not super familiar with VB6 syntax, but it looks like your callback function takes in a long instead of a pointer for that third parameter.  This may be why it isn't getting called correctly.
Justin M.
(3,559 Views)
Hi again Peek,
I found a VB6 example on our website that is very similar to what you are trying to do.  Take a look at the following:
NI-DAQmx: Continuous Analog Acquisition with NI-DAQmx Events in Visual Basic 6.0
I hope this helps!
Justin M.
(3,539 Views)
